Old 07-15-2012, 06:16 PM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default cam
Sounds like to me they don't need to worry about the cam What class do you run in
Donny
Old 07-15-2012, 06:29 PM
hjsmith00843 hjsmith00843 is offline
stock 10/12
Operation Iraqi Freedom Vet!!!!
Old 07-15-2012, 06:30 PM
http://www.youtube.com/watch?v=JJupjO88-Ps
I am the red one.
Old 07-15-2012, 06:31 PM
http://www.youtube.com/watch?v=zbyARsPX0og
Old 07-15-2012, 08:34 PM
Merk Merk is offline
by hjsmith00843
No rules on fuel.
Interresting.....One of the few pulling groups that don't have requirements on fuel. Sounds like your pulling group needs a fuel rule.
austin8214's Avatar
Your club has some wacky rules then. They check cam duration but let you run whatever fuel you want? I can't believe they let you run 26x12x12 tires either. Most clubs around here only let you run 23x10.50x12 in the stock class. Just noticed in one of the videos you posted you said you forgot to turn your electric fuel pump on too. All I can say is WOW to your clubs rules.
Also if you look at Lakota's web site it says they guarantee it to pass a stock cam check. But as someone else here said call them if you have any questions or doubt.
Old 07-15-2012, 09:33 PM
Default cam
Does the piston have to be stock stroke or can you use pop out pistons, in our clubs I pull in, we can run 26x12x12 tires, but can not use electric fuel pumps and have to run no higher than 4000 rpm's, all stock parts in stock class, we can use Tubo blue racing fuel, but I use good old 87
Donny
Old 07-16-2012, 11:50 AM
Great info here so I pulled it from the wanted section to the pullers section without losing any of the info.
Old 07-16-2012, 07:31 PM
austin8214's Avatar
Hey Donny I tried to reply to your private message but it says you are not set up to receive them.
