Ian,
I would install the relay. It takes the load off the switch. You don't want to have to replace many of those for the price. Don't feel bad, those switches are expensive here too. Not that much, but still expensive. |
Ian,
The glow plug timer on my 1772 is attached under the electric fuel pump on the underside of the plate. I know things are priced different on the other side of the pond, but do you have any Kubota dealers around you? Last ignition switch I picked up, last fall, ran me right at $30 from Kubota. Hopefully you can find something a little cheaper. If not, shouldn't have to replace it again for awhile. Todd, After looking mine over again, the wire gauge is pretty small. Too small to power the plugs from the timer IMHO. You're probably spot on. Didn't dig any further under the dash. Too many things in the way, not enough time.
Josh Diesel Cub Cadets........... |
Thanks Josh,
I'll take another look. Ian |
Yippee, I've found the glow plug timer.
Ian |
