Old 11-11-2016, 07:05 AM
I know that but I'm not that good using a voltmeter, don't worry, I'll figure it out.
Old 11-11-2016, 07:44 AM
Nick, with all the other stuff you learned how to do on Cubs don't be intimidated by the electrical side. Time to read, go to Youtube or check with us. You have impressed me with all that you can do at an early age. Keep up the good work and you'll have that 13 fin charging in no time.
Old 11-11-2016, 09:36 AM
DieselDoctor's Avatar
Nick - I'm fairly new to the board so I don't really know, but I gather that you might be a young man, maybe of high school age? No matter! You can learn electrical just as how you have learned other things about your Cub. No question is too dumb, we will help you. You are probably very good with computers and most of us old guys are just learning! Get on the web and Google search "basic DC circuits" and "using a voltmeter" then do a little reading. You may hear someone mention a multi-meter. That's just a hand held testing tool that has a voltmeter and several other functions all in one box. If you have access to one, post a picture of it and we can help you figure it out. We all were your age at one time and had to learn this stuff too. Best way to learn is by doing it!
Old 11-11-2016, 11:38 AM
Terry C's Avatar
Terry C Terry C is offline
Quick test:
Start it up and run half throttle, unhook the battery and if it's charging it will stay running
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-11-2016, 11:41 AM
Thanks Todd, you are right, I appreciate it, I always loved working on these things!
Old 11-11-2016, 11:42 AM
Thanks for the advice, and yes I am in high school, I will try my best to diagnose it.
Old 11-11-2016, 11:43 AM
Quick test:
Sounds good Terry, thanks!
Old 11-11-2016, 02:50 PM
kalebevans kalebevans is offline
Did you try switching the leads on the amp gauge? Maybe someone hooked it up backwards.
Never thought to check, I'm new to the electrical side of these as well. When it's charging it moves the right way, and when I'm drawing from it it moves the correct way as well. I pulled it apart and cleaned the contacts up once to see what that would do, but it made no difference. I hadn't considered it being hooked up backwards, I didn't realize it might do that. I'll switch it up!
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original!
Old 11-11-2016, 04:02 PM
Well I disconnected it and after a minute or so it shut off suddenly, so it is discharging.
Old 11-11-2016, 04:43 PM
Did you have it revved up or at idle? They don't charge at low RPMs.
