Here are the bushings I use.
http://www.oreillyauto.com/site/c/de...5249&ppt=C2456
Easy fix for that problem is to drill and tap the top of the transmission case for a vent. 1/8" hose adapter, some fuel line and an in line fuel filter.
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
The 1512's looking good! On all my diesels, first thing I do is change all fluids/filters, pull the fender pan/tank, flush the tank, and replace all fuel lines, grommets, and fuel shutoff. You'll be suprised how hard those fuel lines are. Then go over the driveline replacing worn parts, rag joints, bushings. Mine were pretty dirty as well under the tank. I'm with Dave, these diesels are nice little tractors. Good luck and keep the pics coming. Fair warning, once you have one smoker, you'll want another...............
Josh Diesel Cub Cadets........... |
he rite i found this nifty little bugger on a local online auction couldnt resist... however the warden had a different opinion!!!
Nice. Did you buy it? It's out of a cub. D600 or D640?
That is a pre Cyclops setup, radiator is on the wrong end for a Cyclops. That said D600 unless it came out of a 1772 then it would be a D640
Since you have your fuel tank out of your machine, is there any way you could get me some basic dimensions? I'm thinking of trying to find a generic tank for my machine to mount in the same spot. Thanks!
never checked it but i assume its a 600
Hey, all - thanks for the replies and suggestions. Between family activities and the weather, I still have not been able to turn the power washer on the tractor yet. I'm hoping to get everything cleaned up by the end of this work week. In the meantime, I'll order those bungs (thanks, Todd) and get the necessary fuel lines (one bung was 'weeping' already). Yes, the lines are hard and inflexible as you would expect after 30 years. The only dumb question is the one not asked, so can I use regular rubber fuel line, or do I need something specific for diesel fuel? I'm still on the fence about the block heater. I don't know how often I'll want to use the diesel in the dead of winter, since I have the master of snow removal already in the 2084 with the 551 blower. I have a 450 blower and a blade that I can use on the diesel, and as long as I act ahead of time, I can always get the diesel into the garage before or during a storm and be able to use the turbo shop heater in extreme cold situations. The new starter is going to be the biggest help, but the addition of the block heater is appealing as an 'option' and it'll never be easier to install than while the motor is out and on a stand.
SamMac, the vent/fill tube looks appealing as well, I'll look for one of your past posts to cover it in more detail (not that there's much to it anyway). It certainly looks like a better option than I.V. feeding 7 or 8 quarts through the dipstick tube. And I'll post pics of the driveshaft adapter today or tomorrow, as I think there's definitely hardware to be replaced there, and any help with part #s will be very helpful. Thanks again, guys. Keep the input and suggestions coming! This 1512 is definitely a long-term keeper!
Tom 105, 149 w/44A, #2 & #4 carts 782 CCC Red w/44C 1512 Smoker w/50C, 450 Blower 2072 w/60" Haban IH/Lawnboy 3322 Pusher, Scag TT 61" JD 455, X495, Kubota 2150, Gravely 450, 812 |
