Old 05-10-2024, 10:37 PM
IHCub1450 IHCub1450 is offline
Originally Posted by DSarow View Post
I have to give finsruskw a lot of credit for the excellent response.The wrench selection is spot on.A non reversing ratchet wrench in that situation could be real trouble.When you get the bolts initially loose,use a short open end.When you reassemble, don't take chances on the conditions of the bolt heads,threads ,lengths. And when you get it supported with the wheels off,give it a little wiggle and push before you get under it.Those pesky bolts might be tight and you don't want to pull it off you supports.Good luck,
Yes, finsruskw gave a very good explanation.
I jacked up the tractor today, put 5 supports on it, and then gave it a good wiggle. I will work further on dismounting the engine tomorrow.
1976 IH Cub Cadet 1450
2006 Cub Cadet GT-3200
