Old 05-04-2015, 11:42 AM
ok let me rephrase this,
Your ball bearings should be snug on the crankshaft, as well as in the bore they are in.
They should be tapped off/on with a small hammer or a light press fit.
if they are sloppy that will cause a knocking sound.
I am not talking about end play.
Hope this helps.
Old 05-04-2015, 11:55 AM
darryljs's Avatar
darryljs darryljs is offline
darryl, you are not following George I don' thing. He is talking about the rear housing. He wants to know if the bearing has a .010" gap between it and the aluminum rear housing. Like around the circumference of the bearing. It doesn't sound like that is the case..... I believe you keep stating the crank end play.
Ok, thanks Jonathan, got what George is asking. I didn't check clearance there. What I mentioned before was that I could remove the alum. housing and bearing, just by pulling it by hand. I could move the crank back and forth (front to back) ever so slightly but I could feel it move. It shouldn't do that, should it?
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 05-04-2015, 12:01 PM
darryljs's Avatar
Hope this helps.
Yep, that helps, a lot. Thanks,I guess I didn't quite understand what you were asking, but Jonathan straightened that out.
Old 05-04-2015, 11:56 PM
The crank should have end play, yes.....
Old 05-05-2015, 12:49 AM
darryljs's Avatar
Alrighty then. Thanks Jonathan, I think I have a handle on it now.
And a big THANK YOU to every one for your insight and suggestions to the problem.
