Old 01-30-2015, 03:41 PM
jchristensen jchristensen is offline
I don't think the pump will work mounted like that. The way you have it mounted now the pump inlet inside the tank will be at the top and liable to suck air instead of oil. You really need to turn it over.
Also, Are you going to shift the pump unit valve and then your auxiliary valve? I can't tell how you are supplying pressure the aux. valve.
Old 03-24-2015, 02:52 PM
I have no fear that it will work the way it is mounted. Worse comes to worse, I take a small piece of tube and attach it to the suction port to put the port closer to the oil. Problem solved.
Outside lever supplies the rear ports and spool valve with flow. Both levers moved together supply the cylinder with flow. So yes, I need to move both levers to move the 3pt lift.
The project is coming along great. Changed the rubber lines to the rear ports over to steel lines and invented a belt tensioner device. Mainly changed to steel due to looks, and it makes it easier to get on/off the tractor. A little more work the another update.
