Old 10-16-2015, 08:49 AM
Head milled bead blasted 30 bux to mill
Old 10-17-2015, 05:50 AM
twoton twoton is offline
Lookin' good.
Old 10-17-2015, 09:09 AM
Thanks David. Long ways to go still. One crank bearing was missing the cage and the other has a rough spot so replacing both of those, list keeps getting longer, what was that you wrote about a hole in the shop floor and pouring in money?
Old 10-18-2015, 08:33 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I'd have the crank checked for cracks . once the cage breaks you don't have decent support all around the crank. have them check the radius on each side of the rod journal. that's where they usually crack
Old 10-18-2015, 09:06 PM
Will regular Magnafluxing work, Don?
Old 10-18-2015, 09:12 PM
dvogtvpe's Avatar
yes........
Old 11-21-2015, 10:05 AM
Scored a steel oil pan, the mounts must be swaybar bushings as "Tenneco" is printed on them. Pretty sure that Tenneco owns the MOOG name. They seem hard. Got 2 new USA made crank bearings.
Cradle mod today as it is rainy.
Old 01-24-2016, 11:04 PM
Mounts ready new locknuts
Old 01-24-2016, 11:08 PM
Box of stuff ready to go, new bearing in PTO, welded muffler shroud, new used muffler, homemade muffler crutch
Old 01-25-2016, 04:46 AM
Good to see you're makin' some progress!
