What he said!
The 2 front bolts that hold the engine to the cradle are accessed directly above the axle. Short of pulling the axle, which would really be a pain w/the with a deep sump engine in place, about the only good way to remove them is to jack the tractor up so the axle swivels up and down.
I have found that the easiest way to remove engines in QL's W/O removing the cradle. For me, installation and/or removal w/the cradle bolted to the engine is by far a bigger PITA that dealing with 2 bolts to the pan. No scratched paint either. Your mileage may vary, I'm sure. Just be sure to use the same or same/correct length bolts when reinstalling the engine to the cradle to avoid issues w/cracked pans due to using bolts that are too long then getting violent with them when tightening. When you get the front of the rig off the ground so the axle pivots, THEN you will likely find that you DO have loose front axle issues. My $.02 worth. |
But,.. whatever. Good luck kid. |
Mudrig why don't you download the service manual and do some reading. You might find it useful.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
I would drain the oil first, disconnect the drive line, then just tip it on its side and let the engine fall out, put some hay or if you prefer some soft downy feather pillows on the ground.
2 guys, safer than one. Just grab it and lift. Air shroud, exhaust elbow, generator on older engines, all good places to grab. DON'T grab the carb/air filter. Could just pull a couple head bolts and install a piece of chain and lift by that. Main thing is to just THINK a moment about how you are going to lift it and where you are going with it. Use your knees, not your back. Nobody tells you that until after its too late......
I'm sure you can find a PDF version somewhere and read it. ~150 pages of good stuff!
-Derek Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46 |
Guess I'll just stick a chain through the original hook bolt and lift it from there. |
Yes sir! Geterdone attitude! I LIKE IT!
