Old 10-10-2015, 07:53 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I agree with Austin. t acts as a back up if you put it against the back of the collar for the spring
Old 10-12-2015, 02:24 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Okay that sounds good, but will it interfere with my rockshaft or lift arm for my attachments? For now I plan on running stock classes and still using it around the farm. In the future if I have a dedicated pulling tractor it would be easy to just remove the lift arm. For now I would like to use it for both pulling and chores.
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 10-12-2015, 09:22 PM
dvogtvpe's Avatar
beats me, I don't keep that stuff on my pullers. if I had to I know I could figure something out
Old 10-21-2015, 11:06 PM
CumminSHO's Avatar
Can anyone shed some light on the situation? If I can mount it close to the steering box? Thank you
Brinly 10" plow
42" deck
Old 10-22-2015, 01:09 AM
Berwil's Avatar
Berwil Berwil is offline
Sometimes you just gotta get dirty and figure it out. The two most knowledgable pullers I know on this site chimed in and gave you advice. It sounds like you can mount the bearing anywhere, buts it's best to support the spring. Maybe if it's in the way when it's up against the spring, you can make a bushing to slide over the driveshaft that will allow you to place the bearing further back yet still support the split collar.
Bill
Old 10-22-2015, 06:21 AM
twoton twoton is offline
That's exactly what I was thinking Bill. You could even add a zerk to said bushing/spacer.
Old 10-22-2015, 10:46 AM
austin8214's Avatar
You don't have to have it smacked up against the spring if you don't want to. Pullers just typically do it for added insurance in case the split collar comes loose. As mentioned you could easily make a bushing though.
Old 10-22-2015, 11:51 PM
CumminSHO's Avatar
Berwil I completely agree with you that I have had some very knowledgeable guys chime in and I will not argue with their advice. I will add an extra bushing to keep it clear of the steering box so it wont put it back into the rockshaft. Thank you guys. I will mock it up the next day when I get a new pressure plate from Zach Kerber Machine. Thank you guys for chiming in.
Brinly 10" plow
42" deck
