Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 05-31-2017, 10:51 PM
ginsenger ginsenger is offline
I have some 5 acres of simi wetland, it stays too wet for tractors to keep mowed till full summer is here, they tear up more than i want to fix. One of my 1811s just blew a rear main seal and really doesn't have the power it ought to. My other one needs a bit of work too but only thing i got to mow with right now. I always wanted a super and a bigger deck. Im 60, working too hard as a masons helper and mech for a big mason outfit and childhood friend an and getting tired. Grass dont care it just seems to grow faster ever year.
Old 05-31-2017, 10:54 PM
The 2072 is closer by 3 hr and would match what I already have but I liked the thought of the 60 inch deck. I really dont like the plastic either
Old 05-31-2017, 10:57 PM
I do have a 3 point tiller and plow and disk that went on an old bolins and a blade for a cub.
Old 05-31-2017, 11:02 PM
I'm a master diesel mech that started before dot made them get em right or not on the road. swapping stuff is not a big problem IF it will fit.
Old 05-31-2017, 11:13 PM
The 60 inch deck is a Habin deck I think, it's a fabricated deck, not molded like the 44s that I have. From what I can tell the plastic is ok, but I haven't seen it myself in person.
Old 05-31-2017, 11:39 PM
$600 won't rebuild it. I'm sure you're capable. It's a matter of cost. You will have as much in rebuilding as a new. Unless you're one of those mechanics who pieces stuff together and doesn't really rebuild engines. Or, unless you own a boring bar and valve grinding equipment. Even then, you'll be lucky if the block doesn’t have a hole in it.
The Bolens tiller won't work on the Cadet. Wrong PTO.
Old 06-01-2017, 12:35 AM
Terry C's Avatar
Terry C Terry C is offline
If you need to mow, then get the big gun. The22 with the Haban will kill grass in a hurry.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-01-2017, 06:52 AM
Leadslingingdaddy's Avatar
If you mow 5 acres then I would think of getting a good ZT to handle that load and use your GT for utility work... The ZT will save you the time to fix your others machines....
I would haggle down the price of the Cyclops if you have to have it since its a drive to get it....
Old 06-01-2017, 07:56 AM
Ginsenger, I looked at the ad, he doesn't mention that this tractor has rear pto. If it did, those 2 options are the selling price of the tractor.
Old 06-01-2017, 11:48 AM
Dirty Steve's Avatar
Buy them both and combine the best features.
