Old 07-06-2014, 09:48 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Thanks, guys, for all the great comments.
CCBob, to use the taller tires (27" tall) I lengthened the frame and moved the transaxle rearward 3-7/16 inches. And I used an 1863 (I think) front axle to get a couple inches lift to level it out. I moved the axle forward several inches also.I did not change gearing. Of course the taller tires do gear it up somewhat, But I figure I am just getting the equivalent of losing first gear which I never used anyway. I am using an old 100 transaxle with the slow second gear and I always thought that slow second gear was too slow anyway. So, I believe I will be alright. Granted, I will have a faster reverse and a faster "road gear".
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 07-26-2014, 06:57 PM
Tim.E's Avatar
Okay, So I didn't like the paint scheme, too much white. So, I made some changes. Here are some pics of what I have now. It is almost done. I need to get some "correct" (maybe tri-ribs)front tires, and get an exhaust stack installed.
Old 07-27-2014, 12:13 AM
Tim.E's Avatar
I want to use 4.00-4.80 x 8 tri ribs on the front, but I can't seem to find any narrow front rims to fit the 1" spindles. Any ideas?
Old 07-27-2014, 02:02 AM
Looking good, Tim!
Old 07-27-2014, 09:53 AM
IHinIN IHinIN is offline
You could narrow a set of wide wheels.
Old 07-27-2014, 09:59 PM
bruce s's Avatar
bruce s bruce s is offline
I made some hubs for the 1" bearings and used 4 bolt trailer wheels to put narrow tri ribs on my super . I think I used 2" scedule 80 pipe for the bearing area and round stock faced and board for the flat part , then some GM press in studs for the lug studs . If you can build a tractor that looks as good as your 106 and 100 you can figure it out . Oh yeh it proubly would be easyer if you was a forman in a machine shop .
Old 07-27-2014, 11:18 PM
Tim.E's Avatar
Adam, Bruce,,,,, Those are good ideas. Thanks
Old 07-31-2014, 10:40 PM
Tim.E's Avatar
My buddy, Jesse Reed fabricated some goodies for this tractor build.
Check this out!
Old 08-02-2014, 09:20 PM
chris hall's Avatar
chris hall chris hall is offline
Check this out!
that is a really nice grill guard.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 08-07-2014, 09:18 PM
garnold's Avatar
garnold garnold is offline
Do you have a build thread for this beauty? I'd love to see how and where you made those alterations to the frame. I'm really liking this build and can't decide if the white or red color scheme is my fav
