Old 03-10-2014, 10:40 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
looks like it just came out of the box.
nice work!!
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 03-10-2014, 11:02 AM
It looks nice, but I think you are going to find that it won't "suck" itself into the ground. The plow point doesn't angle far enough forward. Needs more curve to it. (See pic below.) No, I doubt a 12hp would pull 3. Not very deep anyway, and like Sam said, it would be "tractionally challenged". If it does go in the ground, I think John is right on, you'll need a wheel.
See how the shares on the ripper sit at a less than 45° angle? That's what makes it "pull" itself into the ground.
Old 03-10-2014, 01:43 PM
clint clint is offline
I don't think you will have any problem getting it into the ground, now controlling how far it goes into the ground you may have a problem. It doesn't look so much like a subsoiler, more like a layoff plow or something like that. I'm not sure how good a GT will pull it either I have seen videos of GT's plowing however here in Georgia red clay I gave up on dreaming of plowing with a GT. Below is a picture of a single subsoiler the only place I have ever used a subsoiler was in a pasture to create water retention.
1440
1282
1604 cast rear/transmission (582)
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
Old 03-10-2014, 10:05 PM
john hall's Avatar
I think it will go in the ground as well. I've got a single shank subsoiler I made by using the shank from a Taylor-way subsoiler designed for a Farmall M and building a 3pt hitch to fit a 90hp tractor. The shank design on it is about the same. I can drop it in at least 18". I'm curious where the hardpan on a garden spot would be, maybe 6-8" if it has been continuously worked with only a tiller? I really think this will improve how well a tiller and disc perform. Should improve yield on sweet corn too!
Old 03-11-2014, 12:10 AM
I guess we will find out when he sticks it in the ground whether it will work or not. It really all depends on how deep he wants to go. That is scarifier shank off of a box blade, and I've tried to use those for ripping before. They weren't curved enough. Went in about 4" and that was it, and that is with a BUNCH of weight on it. It's all about the curve/angle. The hard pan is in the same place it will be in any other location in his area, being a garden doesn't change that. I don't know where that is in PA. In the part of Ill I'm in, the hard-pan is about 12"-14".
Old 03-11-2014, 01:30 PM
john hall's Avatar
You're right about the hard pan. I should have been a little clearer, meaning the ground should get quite a bit tighter once you get beyond the zone normally tilled, but certainly not to the point it will fracture and lift when ripped.
Old 03-11-2014, 01:59 PM
Agreed!
Old 03-14-2014, 10:55 PM
EricR's Avatar
EricR EricR is offline
Attachment 48348
Not to hy-jack this thread but this contraption is a lime truck's worst nightmare (ask ME how I know). LOL
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-15-2014, 01:42 AM
I don't know of a GT that would pull a sub soiler in the first place as far as pulling it 14" deep, BUT maybe I'm wrong.
1440
1282
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
Old 03-15-2014, 06:18 AM
IHinIN IHinIN is offline
Here's the subsoiler I built. It works decent but I had to add weight to it to get it into the ground. It needs a longer point set at more angle to help pull itself down. It does pull down better in hard packed ground than it did in my tilled garden. It went in about 12-13" in sod and had no problem pulling it even with the Sears turf tires.
