Old 01-18-2015, 09:38 PM
Am I correct in thinking that if you rotate the charge pump, it only reverses the direction of the "needed input" and doesn't reverse the direction of the output?
So, if you rotate the charge pump AND flip the ring gear... It will go backward with the lever in the forward position. Is that correct?
No, since you reversed the direction of the input, then you have to flip the ring gear to the opposite side. If you don't, the handle will be backwards. That's why you flip the ring gear, because the output is also reversed.
