I sand my grills and wheel weights with a DA sander. Just took the really high peaks off.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Sent you a PM.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
There are aluminum ones out there, and are smooooooth, just need to find one though...
The casting has "texture", not pits, sheesh!!!
How is removing the casting texture on the grille the tractor came with "restoration"???? Sounds more like a modification to me...
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder 3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller 1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers |
What he said. Castings rarely "pit", just clean the rust off, slap some primer and paint on and go.
Here is one I did when I was 18. We used wire brushes (lots of them) to clean it.
The lower casting is supposed to be rough... that's how cast iron parts are.. wire brush it, prime and paint!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Body fill
Despite my better judgement I’ll chime in to this controversial subject: similar to painting a Cub Cadet - Green. What you can do is 2-4 coats of high build primer and / or a skim coat of 3M Premium Glaze or “Body Fill” also EverCoat Rage Ultra is some good quality filler. Do not buy USC or Bondo brands as they are a nightmare to sand. Spend a little extra, a quart will be more than enough. Start with 80 grit then work up to 320 or higher to avoid sand scratches showing in the final paint. It’s not for the average re-paint but if you want the best quality then you have to do what no one else does.
