Old 05-30-2014, 12:56 AM
My thoughts would be on uneven ground.
As your cresting a hill what's going to keep the mower from rising, or is it going to have adjustable wheels with swivel at all for corners for height adjustment, and stay on the ground?
Will the loader have float so it follows the contour of the ground? Would almost have to, right?
I know, so many questions.
Old 05-30-2014, 12:52 PM
terkaa's Avatar
terkaa terkaa is offline
Hi,
There are oval mounting holes that have about 3 inches of "float" movement(you can see these in first pic). I tried it first time today but it is raining here so I wont be able to properly test this "thing" before we see some sun again(But it did rotate & cut grass).
Tero
Old 05-31-2014, 08:40 AM
terkaa's Avatar
Ok first lawn done
It seems to work ok. Pressure required is 100 bar(Lawn was long and wet so lower pressure probably is fine for "normal" lawn). Gauging wheels tend to make skid marks as they do not "steer".
Tero
Old 05-31-2014, 09:14 AM
Inactive Member
Fabricate some casters for the front of the deck. I did on mine.
Looks good.
Old 05-31-2014, 09:23 AM
What did you use for the hydraulic pump and motor to drive the deck and how are you driving the pump? Awesome looking setup. Some casters on the front of the deck and it should be sweet!
Old 05-31-2014, 10:35 AM
Looks like it worked nicely for you!
Old 05-31-2014, 10:49 PM
Thanks for the update! Looks good!
Old 06-01-2014, 12:36 AM
Looks like my concerns were for not. Well done
Old 06-01-2014, 02:04 AM
bocephus1991's Avatar
Pretty cool! Will the hyd pump on your cub hold up to that much continuous use? Reminds me of the side mounted brush cutters used on road sides an trimming tree limbs.
Brian
Old 06-01-2014, 07:02 AM
terkaa's Avatar
Because of a lot of interest here is a pic of pump and its drive. It is standard gear pump driven by belt from front PTO. I am going to replace it with a slightly bigger pump and move it under hood in front of engine. This pump is just enough for rotating blades and lifting boom but just and just so I want bit more also I am going to build backhoe so it also needs a bit more flow. And it is currently mounted too low. I will post pump exact size after I verify it.
