Old 01-30-2013, 07:43 PM
Merk Merk is offline
by dvogtvpe
dvogtvpe actually the 301 crank will fit the 241. you can use the 301 crank and rod with a 10 piston but the wrist pin holes are different size's to you have to address that
Thanks Don
I knew something made it costly to do.....just didn't remember what it was.
Project Uncle Dick
Cub Cadet 70
Old 01-31-2013, 02:20 PM
hjsmith00843 hjsmith00843 is offline
when building a stock class puller here is what you need in gaskets.
copper head gasket (if allowed)
Copper Sidecover gasket
Rest of the surfaces use black RTV
Use a 18HP Alcoa rod with a stiens piston.
Fresh valve springs. Dont port it. Porting a stock motor will only hurt your performance.
Operation Iraqi Freedom Vet!!!!
Old 01-31-2013, 06:02 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
stock ports actually outflow what the stock valves will allow
