Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 11-20-2014, 07:38 PM
Ok. What about the needle on the main jet adjuster? Are the holes in the needle clear? Best way I have found to check is to take a brake cleaner can with a straw and put the straw directly in contact with a hole in the needle and spray. Look for liquid to shoot out all the holes. If it doesn't, they are plugged. NOTE: Wear eye protection!
Old 11-20-2014, 07:53 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
which holes is your governor spring in?
Old 11-21-2014, 06:37 PM
IH_147's Avatar
IH_147 IH_147 is offline
im prett certain there clear j mech and its in the approperate slot
100,122,126, 126, 126, 147,147,800,127, 982, 1210, farmall 300, farmall 560 diesel
Old 11-21-2014, 09:35 PM
I've heard both of those statements before.......
How about you check and make sure they are clear. And tell us what holes the spring is in, (or a pic). Not that we don't trust you. But many, many times before I've seen where someone really thought they knew what they did was right, and it wasn't. You asked for help, please just humor us.
Old 11-21-2014, 09:47 PM
IH_147's Avatar
haha no problem gents ill get them soon
Old 11-21-2014, 10:15 PM
Thanks!
Old 11-24-2014, 06:12 PM
IH_147's Avatar
well guys i believe ive diagnosed the problem the governer shaft bushing on the carb is shot and is sucking air. Ill let you know if this fixes it any inputs appriciated
Old 11-24-2014, 06:18 PM
Do you mean throttle shaft?
I thought you said it was tight?
Old 11-24-2014, 06:55 PM
IH_147's Avatar
yes the throttle shaft and it is tight the specific way i moved it my dad came and found it out
Old 11-24-2014, 07:03 PM
When you rotate it, it has a "flat spot" in it? Is this correct?
