I've never seen a delivery valve stick shut. Just stick open. Think about it..... it's a high pressure pump. If the delivery valve stuck shut, all that pressure has to go somewhere..... things would seriously come apart if they stuck shut. When the delivery valves get "sticky" they will open, but stick that way.
Take the exhaust manifold off and try starting it with the throttle wide open and look for puffs of smoke coming from every one the exhaust ports. If you have fuel and compression it should puff smoke out of the exhaust ports while cranking. Check the muffler for debris and being plugged up. If it was turned up there could be a bunch of crap in it. Mine came turned up and full of crap. Check valve adjustment and compression also. A diesel compression gauge for about 30 dollars is available from Harbor freight. It's a cheap setup but will get the job done.
