I don't have the tin in place between the engine and the battery. Some say that will cause the engine to run hot which will heat the fuel. I have also read to shut the engine off hot at full throttle as idling the engine before you shut it off makes the engine hotter. Don't know. I have two other Commands and neither of them have had this problem. |
If I understand it correctly the fuel solenoid does not cut the fuel off at low throttle when idling. Only at 3/4-Full throttle. So, perhaps I should idle it for a time to cool down and then return to 3/4 throttle and shut it down there preventing fuel from dumping in the carb? Please anyone correct me if I am wrong with how the fuel solenoid works.
Nathan Gardners, PA Cub Cadet Yanmar SC2400 |
Fuel solenoid is electric. Throttle position has NO EFFECT on it.
If my engine hadn't straightened itself out (for now) my next step was going to be to pull the top off the carb and check fuel level in the float bowl and see if the fuel solenoid was retracting like it's supposed to.
You could try the same to check out the "gasoline evaporation" theory. |
Yes and no, not a blanket statement for all. For the engine discussing here, JMech is prob right. For the newer commands such as the CH680, shut off solenoid shuts off only high speed circuit fuel, idle circuit is not affected thus if shutting off a hot engine at idle, it will run-on. The manual suggests high throttle position shut off, I use mid throttle and it works. Weird, dumb design.
Something I didn't mention about my situation. When I turn the key off, the ignition doesn't ground and kill the spark. The engine shuts off after the solenoid closes and shuts the gas off to the engine so it does control low speed fuel feed. CH 18/20.
