You can do very well in a stock class without cutting anything up. Most of the things you add for pulling just bolt on, and can easily go back to stock.
Randy
2 original cub cadets 1 100's 2 149's 1 73 1 2182 |
Ok here are the rules for bone stock class. Going by these rules. Obviously I can still a .330 lift cam in it but doesn't say much else engine wise. Could I within the rules bolt on a LP head? Doesn't look like they would alow any port work.
Bone Stock Rules 1. Factory stock, commercially available garden tractor frame with stock running motor. Does not have to be motor that came in tractor. Frame can be modified only to accept motor. 2. No high performance alterations to engine. Stock, OEM available, unaltered replacement parts only!! For the following: valve train components, piston, valves, stock deck height, crankshaft, cylinder head, and ignition system: stock OEM system, either points or electric replacement for that engine unaltered. Exclusion are: clutches, belts, and pulleys. 3. Carburetor must be stock, unpolished and unaltered. 4. 18hp cams or stock lift (0.330 cams) stens, and rotary parts are allowed 5. Connecting rod can be altered for bearing only. 6. Chevy points are allowed, but no electronic ignitions or trigger fire (such as MSD or Accel). 7. Steel flywheels are allowed. 8. No welded rear-end. No locked rear-end unless you can prove they are OEM from factory. 9. Maximum bore size .030 overbore from standard specs. 10. Governor control must be working. 4000 rpm max no exceptions. Rpm’s will be checked. 11. No intake standoffs or velocity stacks. 12. 12 inch max hitch height. 13. Must maintain stock wheelbase. Lite weight front axles are allowed as long as in stock location. 14. Pump gas only. (Racing fuel and Aviation fuel are allowed.) 15. Max engine size is 14hp single cylinder. 16. There are two different tire classes. A. 23×10.5×12 turf tire no cut tires. B. 23×10.5×12 bar tire no cut tires. |
Thanks guys. The first thread i read here was that one. Thanks again!
Since the rules say stock lift cam, how about a Zach Kerber gov 3 cam, LP head and fine tuned. Looks like that's all I can legally do... says I need stock valve train but that cam requires jeep lifters and recommends better springs... it says stock valve train so not sure that would fly or not. Probably have to go with the gov 2 cam they offer as it says I can use stock lifters/springs etc.
