I guess if I was you I'd take a few days off and calm down, then start a systematic approach at the problem. go over what you've done and check things you haven't. obviously you are missing something . these are the simplest of engines to work on.
what were the adjustments you made when you changed oil? |
Test the condensor or replace it with a known good one.
replaced the battery, replaced the S/G with a newer one, new points, new condesor, new push rod for points, adjusted the valves (mainly exhaust), fixed the ACR, checked the head gasket and head, decarboned the piston and chamber. and new oil
Brandon CC models: 86, 1650, 100 w/hanban sickle mower & 1872 1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade 1978 1650 Hydrostat w/44" mower & 42" IH push blade 1965 100 w/hanban sickle mower 1989CCC 1872 w/50c mower |
ol george i replaced it about a month ago but i may have to get a new one
try running it with the point cover off, just a hunch, it is a no cost thing. I've seen it before. |
well i tried that today and it ran worse...just trying to elminate my problems, cuz it ran great until i serviced it fully this go around...im thinking maybe the cam lobe is wore out
If it ran great before, it isn't the cam. Probably not the push rod either. You have got to be over looking it. Did you time it with the flywheel and a light or DVOM?
jon...no offense but what is DVOM?? i usually just guess at timing them and get it right...as for timing it with a light and flywheel i cant find any marks on the flywheel.
Brandon
Take a look at these from the tech lib. http://www.onlycubcadets.net/forum/showthread.php?t=14 http://www.onlycubcadets.net/forum/s...ead.php?t=4405
thanks sam mac. i will try that once the rain and snow lets up here...ive got it covered up now...but i hope to find the S mark...cuz its hard to see on my flywheel..
also ive heard of electronic conversion on the kohlers any ideas
