Keep us posted, I look forward to seeing your progress.
finally more progress
so im starting to get things in order now. i mounted a jd 317 pto clutch on the vanguard. got a new carb and it runs great now. should be a nice setup lots of deck speed with low engine rpms and a recoil backup in case the battery goes dead or something. waiting for a different oil filter mount for the engine then i can bolt it in. to keep this rig from getting too long i shortened up the mule drive/deck hanger assembly by 8" so the deck is essentially all the way to the front now. i plan to chop off the extra frame in the rear once i mount the tires and build a hitch.
John, PROUD OWNER Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow, 1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer. |
Looking good! I'm liking the sounds of this project more and more!
Sam,2-149,102-with creeper,102,125-parts,147,682,682-Cub Ca-table,1440 4cyl-(work in progress),3165,154 lo-boy with 3 cyl. diesel, Shed full of parts and accessories |
so the engine is mounted in. i had to notch the frame for the oil drain out the front and the oil filter on the side.
today i crudely mounted the rear wheels and chopped off the excess frame. ill skip the boring details from here on. if anyone wants more detail as i go please ask
I vote for MORE details!
Wow!
5678 |
i can tell you guys that i had to widen the frame on the right side to clear the starter, and cut a hole in the left side to get the oil filter to fit. if this was still a 1650 im not sure how a vanguard would have fit without these "mods"?
the rear wheels are stock cub cadet front wheels. i mounted them on an axle made from HEAVY 1" square stock with a 3/4 hot rolled steel shaft plug-welded in each end. i drilled and tapped holes in the ends of the axles to hold the wheels on just like the front of a cub cadet tractor would be. then i welded everything up and chopped off the extra frame in the rear. i plan to pretty up everything once its functional. next to build the hitch...
