Old 03-26-2013, 12:55 AM
1811woody's Avatar
1811woody 1811woody is online now
Nice job! The lever configuration looks well thought out
Old 03-29-2013, 03:06 PM
Jumper Jumper is offline
I played around a little more with the spool valve mount so I could mount it correctly. Sorry about the pictures, for some reason their kind of fuzzy .
Mounted the valve to the mounting plate, red rubber coated the the ends of the control levers, mounted both valve and levers in the test dummy and connected with a chain connector link A2050. I was able to use springs and washers on connector links to finish align the levers in the dash slot -or- I have to elongate the valve mounting holes to the right to help with alignment. The outside lever has to be bent in a little to clear the dash when the valve is in the float position but other wise looks pretty good for fit.
Old 03-29-2013, 03:08 PM
Good job! Please keep the pics coming!
Old 03-29-2013, 03:36 PM
Looks great!
Old 03-29-2013, 04:15 PM
Nice work.
Old 03-29-2013, 04:31 PM
Good job!
I like the looks of the three levers!
Old 03-29-2013, 06:19 PM
Thanks again guy's but I have to admit, for as many show's that I've been to I've only seen two 982, three lever hydraulic factory machines. I wished I'd would have taken a longer look to see how they did it ! (I can't believe Cubcrazy doesn't have one.......or does he ????????? hmmmmmm)
Old 03-29-2013, 09:13 PM
No three lever 982's here Jumper!
