look like fsm is here.
I must be a maroon,
except for heads and bearing plates I ain't got much use for a torque wrench. |
the rest is "Goot N Tight" by Armstrong Ya? (Well I do use an inch pound on valve bodies for automatic transmissions.) |
Good and snug plus a bit. Bigger stuff gets a few battery powered ugga dugga's.
I think the OP is over thinking this.... sure, there is probably a torque spec, somewhere, but it is a 3/8" I believe, bolt into cast. Good and tight will do. I'm not saying put a 3' breaker bar, just a regular ratchet or box wrench will be fine. |
What ol, George says. SWAG and feel. remember its cast iron.
Back around 1967, I was in Tech School in the Air Force, we were removing, rebuilding and reinstalling a landing gear wheel brake on an F-100. Had a large socket with a 5 ft breaker bar to remove the brake, when we reinstalled, I tightened the nut back on with that same tool. The instructor came up and said, “ what did you torque that nut to". Being a smart ass 18 yr old kid, I said “about three grunts” with a smile. Well that reply got me the task of writing out the tech order instructions of: removing and installing the wheel brake on an F-100, 3 times. The Military has the proper “ how to do it technical orders on everything” lot’s of torquing, and safety wiring on aircraft.
