Old 06-18-2011, 11:12 PM
MOturkE's Avatar
MOturkE MOturkE is offline
I didn't repolarize it after I cleaned up the inside and reinstalled the S/G. I didn't get that far before I had to put the Cub away for the evening. I'll try to do that tomorrow - after church, of course.
"A small multimeter will not be of sufficient capacity to check amp/charge but you can check voltage @ the battery with it."
I think I might know why my multimeter died on me... However, the local hardware has the fuse for it, maybe that'll get it going again.
Proud to own a 1965 Cub Cadet 122.
Old 06-18-2011, 11:26 PM
HA,LOL!
you wouldn't be the first!
dat be why dey putts fuzes in dem.
also helps when you have a oh s--it moment,
because them little numbers/ scales/knobs all look the same in the bifocals
Old 06-18-2011, 11:39 PM
william1041200's Avatar
Im not too sure about polarizing a s/g. Hope you meant the regulator, as that is the only component relating polarizing, but I have heard that they polarize automatically as installed on a cub. I don't know, guess it wouldn't hurt to do it anyway on the regulator.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 06-19-2011, 09:32 AM
Here is a link to some service manuals.
Hope this helps.
http://www.ruiter.ca/mc/info/PDFs/1R-115.pdf
http://www.ruiter.ca/mc/info/PDFs/1R-116.pdf
http://www.csobeech.com/files/DelcoOldGenerators.pdf
I have abetter copy of the third one .
Up to 530 and counting...
Old 06-19-2011, 10:58 PM
MOturkE's Avatar
Wow, Thanks for the links! I doubt one could ever have too many manuals.
Old 06-20-2011, 06:39 PM
MOturkE's Avatar
I was checking the wiring diagram for the 122 and noticed the GEN wire from the VR was routed to the FIELD terminal on the S/G instead of the ARMATURE terminal. I rewired it, polarized it and jump started the engine. I followed the steps to check the charging system and the engine RPM's dropped with the jumper connected. Now I have to put a full charge on the battery and get an ammeter connected to see where I am at this point. At least I know the S/G is still good!
Old 06-20-2011, 08:03 PM
Great news Tim!
