Old 03-31-2019, 10:28 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Good score on the 1050 and your already making good progress I will definitely be following this thread I love the 1050s
Old 03-31-2019, 10:36 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
One more update. I didn't pull the steering column yet. Most of the play was due to the big bolt that holds the box together was way loose. To the point I can turn the nut with my fingers. I snugged it up and it steers great now. A couple rod end have a little play, but not bad. Look what I found when I pulled the steering wheel cap off! I think this tractor has less than 500 hours and was well taken care of.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 03-31-2019, 10:39 PM
Shrewcub's Avatar
Thanks! Every once in a while a blind squirrel finds a nut! I am well overdue!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 03-31-2019, 11:08 PM
CubDieselFan's Avatar
My 1050 was the first tractor I bought myself. I traded it for my 1572. Nice save on your tractor.
Old 04-01-2019, 08:44 AM
Darrell Darrell is offline
AFAIK , there is no difference the way the cast rears bolt in.
I put a cast rear in a 1050 a few years back and i had to drill two holes in the frame because the aluminum rear had two bolts offset different than the cast rear. Seems like it was the middle bolts ??
I bolted in the front brackets and seems like the rear bolts were lined up but the middle bolts needed new holes drilled in the frame.
I am old and i have CRS , but there was a difference between the cast and aluminum rear bolting in.
Good Luck !!
Darrell
Old 04-01-2019, 10:45 AM
There is suppose to be a nut under the cap Mr. squirrel.
Must have low hours as the pedal is not worn out...
Up to 530 and counting...
Old 04-01-2019, 08:33 PM
Shrewcub's Avatar
I am just going to leave this for today's update.
https://youtu.be/egE0RlXOrQo
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-01-2019, 08:55 PM
It looks like you were busy today. No smoke as I can tell. That shroud still has the decal on it so it must not have a lot of hours on it.
Too bad the 1050 does not have an hour meter on it.
Is that the pto bearing making all that noise?
Old 04-01-2019, 08:59 PM
Shrewcub's Avatar
My eyes couldn't see any either. I haven't pulled it off to confirm, but that's what it sounds like. I happen to have a few of those in stock
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-04-2019, 11:03 AM
Shrewcub's Avatar
Got alot of small things done the past 2 days. Took the lift button out and cleaned it up and made a float pin. Shortened up the brake rod. Had to bend the arm the clutch switch and return spring mount to, as the spring was rubbing the rockshaft and making a horrible noise. Replaced the noisy PTO bearing. I used the lengthened driveshaft from the 122, that donated the trans, to measure the driveshaft length. I got the front trans to frame bolts in. I loosened up the rear ones and jacked up the front and they lined up with the holes right in front of ones for the aluminum trans. Cleaned out the diff and put new fluid in. Lubed up the brake and rockshaft. Picking up some parts Saturday. Hope to be driving it by Monday.
Oh, and apparently the cam stop is different from a hydro lift. I borrowed the one from the 1862. I will have to find one, I guess.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
