i've only had my 42 on my 125 once, just to move it into the shop, and even with the spring assist it was still a 2-hand lift. definitely heavy.
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! |
Hydraulics all the way!!
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
If I can ever finish removing and replacing a chunk of the slab in my garage (huge cracks always losing bolts and such down them) I am going to be fabbing up my own electric lift for my 104. I think I have a plan. That will work. I'll be using a 4" stroke 1000lb dynamic 2000 lb static linear actuator. The modern actuators are much faster than the old one that came on the 147. I'd say this one I'd about half way between the stock 147 electric lift and any older hydro lift tractor.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
I have a 126 that I bought in which a PO made a modification and hooked up a winch to lift the blade. You can buy a cheap winch for about $40 at Harbor Freight an it would be strong enough to lift you snow blower.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Spring assists are the shizzle. They make life so much easier and normally people don't even know they are there.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I converted my 127 to hydro lift. Took some time to everything right. But well worth it
I just put a hydro on my 107, bolted right up and pulley matched perfectly. I had an electric lift before this is much better.
1970 Cub Cadet 107 currently being restored. |
The 107 and 127 are a direct bolt on. The 147 is quite a bit different.
My 147's have electric lifts and I don't care for them very well, they are kinda slow and I don't think they would last very long lifting anything very heavy. If I were going to lift a tiller or blower, I would definitely add a spring assist (or two) and be seriously hunting a hydraulic lift.
I have added a hydraulic lift to one of my 70's my 100, one of my 122's and to my 128, I have all the parts needed to do 3 Wide Frame tractors. I'm just getting too old and broken down to be lifting that heavy "stuff" by hand... I don't think that the 147 frames have the holes to mount the Narrow Frame style Hydraulic Lift, so you will have to drill them yourself (not all that hard). I do know that the electric lift rockshafts and the hydraulic rockshafts are different, so that will need to be changed or modified (I believe that just the upper bracket needs to be changed). Not trying to step on any toes, but I believe that if you use a Wide Frame 14 hp flywheel screen, no other modifications will need to be made to finish your installation. Not a simple bolt on application, but a 147 with a hydraulic lift would be a real Gem to have in your stable!
Resurrecting this thread- I know I previously stated that I'd stick with an armstrong/spring assist lift, but I'd sort of like a hydraulic lift on my ole 147 too. I've been searching for posts on what that looks like (one of the external NF ones) - I saw a previous post about it being somewhat a PITA- no pics though. I don't have an E lift on mine and don't have an interest in putting one back on.
Furthermore, what controls the depth on those? I know on my manual lift there is a stop bracket- does that still work with the hydraulic lift? Does the pump and cylinder interfere with the adjustment nut? Thanks
