cub
That's an interesting idea. Will have to check it out. Thank you.
Yeah, but that's overdrive from stock. Not 43% overdrive from direct. It will speed it up, but not as much as direct driving the trans like a Lo-Boy.
Using a 48 inch tire, and with MWSC gear ratio calculator, a 47% OD gear set and Lo Boy final drives, would result in ground speeds of ---------3rd------2nd--------1st at 4:1-- 8.0----- 4.6-------- 2.7 at 5:1---6.4------3.7-------- 2.1 mph
That can't be right. Top speed of a Lo-Boy is only 8mph in 3rd and it's trans is direct drive, and had roughly 48" tires on them. I'm not where I can figure it out right at the moment.
Best thing to do would be to direct drive the transmission. |
That 8mph speed is at 2200rpms also
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
That is correct. Didn't think about that.
OK, just need to find a set of final drives..not in any rush, will have to keep my eyes out.
Look at these pictures. One has a short shaft, the other has a long shaft. How would these work?
Those are off of an F-Cub. You need off a Lo-Boy. I *think* you can change the shaft, but not sure.
I have a parts Lo-Boy...... both finals.... |
