Old 01-01-2021, 10:01 AM
mlk77 mlk77 is offline
Originally Posted by rwairforce View Post
I have a similar drive.
My 54" plow has a piece of rubber that was cut from a thick mat or runner of some kind. It's bolted along the bottom and is about 1/2" below the blade. The nice edge of the rubber is square and very tough and glides across the asphalt. Works great. Try it with yours.
I was thinking of some type of rubber or I believe It's some type of poly they use. Not sure what's available in my area. This morning I recalled I have a bunch of metal door frames I might be able to use.
Old 01-01-2021, 10:30 AM
Need to be at least 3/16" or 1/4" thick to last very long and be sure the "shoes" are in good condition and adjusted about 1/4" below the edge of the wear blade.
You do not want to wear it down to the point where the bolts and holes are getting worn into.
Old 01-01-2021, 11:09 AM
rwairforce rwairforce is offline
Default rubber edge
Agreed with thickness. It needs to be up to the task. Mine is probably 1/2" thick and I think it may be from a conveyor belt.
Mine runs smooth without jumping, raising or chattering. Of course my plow is of good size and weight so I'm sure that may help. I could see those issues surfacing with a lighter plow.
Good luck. Can't hurt to give it a try and I'm at least one that has used it for multiple years without issues.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 01-01-2021, 11:26 AM
I bought new shoes last year. One shoe was missing the other other was on it's way out. I'm looking into the options for the scrapper blade. I found a thick piece of metal from a old farm trailer I had that would work.
