Old 08-12-2023, 02:02 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Sent some paperwork to this bloke , have not had a response as yet , trust he got it
Oz
Old 08-12-2023, 06:47 AM
Inactive Member
He hasn't checked-in, in 3 days.
Old 08-12-2023, 06:46 PM
Ozcub's Avatar
Thanks Roland , I sent it to his email address , thought I would get a reply
Oz
Still no response 17/8/2023 posted
Oz
Old 09-08-2023, 06:05 AM
Nubuilder Nubuilder is offline
In my single-minded way, I didn't think to check back in here...
I've located a GT2550 fairly close to me (2hrs away) for a great price. Reportedly it runs, but the fuel pump is leaking allowing fuel into the crank. Going to look at it today.
My plan is to either keep this thread updated with the swap or start a new thread. I don't know how quickly the swap will happen if I do bring the GT2550 home.
Old 09-08-2023, 06:08 PM
Well....the GT2550 came home for $200 with 482hrs.
Took the valve cover and fuel pump with me off the 3225. Put it on and it fired right up. Seems to run great. No smoke.
From brief inspection, the PTO on the 2550 is electric with a single pulley VS the vacuum actuated dual pulley on the 3225. I'll have to see how that'll work out.
As I said in my last post, this swap won't be done quickly.
Old 09-08-2023, 07:01 PM
Ozcub's Avatar
Nice machine , have resent info to you
Oz
Old 02-27-2024, 11:19 AM
Yardman Yardman is offline
I replaced my CH225-66549 with a 24 hp PA-CH-3328.
The 66549 had a very similar failure. A rod broke and caused catastrophic failure as indicated by a 2" diameter hole in the same location you described (behind the starter/solenoid)
The 3328 didn't have the exhaust manifold "hole" that supplied the PTO with vacuum so bypassed that by installing a separate 12v vacuum pump and line. I guess I could have torn down the new engine and installed a different manifold and vacuum line.
I wonder how many other folks out there experienced broken rods in these engines?
Old 02-29-2024, 01:20 PM
Rex B Rex B is offline
Default Post a chart?
If any of you do the research on the critical differences in this engine family, please make a chart and share it here.
