Old 08-27-2019, 09:03 AM
cooperino's Avatar
Flateary will git ya no- whare.
Was waitin' for me biskuts "N" gravy to warm a bit,
and solve bigger problems, like global swine flatulence.
so eat mo' Bacon.
Do pigs fart methane?
They're not as bad as cars or cows, but termites fart a lot, and because they are so numerous, that results in a lot of methane. Each termite only lets rip about half a microgram of methane gas a day, but every termite colony is made up of millions of individuals, and termites live all over the world.
HAHA.. Watch out for dem der termites..
Old 08-27-2019, 09:59 AM
Originally Posted by JoeMopar View Post
Update to my issues.
So I cleaned the battery terminals , and the points. Charged the battery cause I forgot to shut key off yesterday.
Joe
Did you recheck and clean the points again after doing this?
The others are fart smellers... I mean smart fellas and have given some good advice.
Keep us posted.
Up to 530 and counting...
Old 08-27-2019, 10:20 AM
Keep us posted.
I represent that fart smelller remark.
Now as far as hawgs farting, yep their shit stinks.
Don't know if it is methane or udder "tanes" like octane?
When I used to clean the hawg barn, it was noticeable, but after a while I got used to it.
Bacon sure smells good with eggs and biscuits/gravy.
But I ain't gonna think where eggs come from.
Once I lost my chewing gum in the chicken yard,
---------Thought i found it 3 times!
Old 08-27-2019, 06:19 PM
JoeMopar's Avatar
JoeMopar JoeMopar is offline
Yes I cleaned battery terminals and points after seeing that key had been left on. I connected a wire from positive post of battery to position post of coil and still no difference.
Joe
Thanks,
Joe
Presently have :
100
1200
1250
Old 08-27-2019, 07:06 PM
twoton twoton is offline
How you going about cleaning the points? If you run fine sandpaper between the points to clean them you may leave grit that interferes with proper contact. Drawing a clean piece of paper between the points after the sandpaper or brake cleaner then compressed air will help remove the grit.
Old 08-27-2019, 07:26 PM
A strip from a brown paper bag will work good.
Actually they always told us not to use sandpaper, but to use a diamond dusted point file, but most fellers don't have them and auto stores look at you goofy and ask what are points, or a point file?
http://www.sulco.co.nz/Tools/File-Se...nts-Files.html
And for my outback friends,
https://www.australianonlinecarparts...k-of-2-t~25131
Old 08-27-2019, 07:28 PM
...or match book cover.
Old 08-27-2019, 08:00 PM
cooperino's Avatar
I use my wifes very fine Emory board "which she hates" then I spray a little brake cleand and dry with air pressure.
What's your points gap after cleaning twice?
Old 08-27-2019, 08:09 PM
I was told a dollar bill works to clean the points after filing.
Fold it in half like this... oh my!!
Old 08-27-2019, 09:55 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Last time I used it on Saturday it seemed like it was running out of gas
Somehow, I think you have more of a fuel problem rather than electrical ignition problem. I know you see a wet plug and I know you dropped the bowl and you thought it looked good. That alone doesn't eliminate a fuel issue. I'd pull the carb and clean it.
Other than that....going back to electrical: Try new plug. Could be fouled. Replace the condenser and be sure it's installed properly on negative side of coil.
Plow blade
#2 Cart
QA36 snowthower
