Hi, I got a 982 that I'm putting a ch23 into too. Could you tell me what you did for hooking up the driveshaft.
Thanks |
Onans have no spacers.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
So is all I need is a spacer from like mid west super cub. Then bolt the Flex Disc to that?
a little ange with stock height
Ok, thanks. I will check that when I drop in my engine. Thanks for the help.
I converted over to the 2000 series driveshaft. Do a search for posts by Sam Mac and you will find the drive shaft mod. It works great.
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
Get a pump adapter from Jeff in PA and a complete 2284 drive shaft and be done with it.
Hey Sam Mac, I read a thread about converting over to the 2000 or 3000 driveshaft of yours. Got a few questions about it. I'm guessing that a 2000 Ser tractor has a spline input shaft on hydro unit? Also, I'm putting a loader on my tractor. What ur thoughts on the 2000 driveshaft hold up to that. Or should I do a CV driveshaft. I read one guy had a problem with the new drive shaft and want to a CV drive shaft.
Thanks |
Ok, thanks for all the help............
