Old 08-12-2014, 08:56 PM
danfeste danfeste is offline
The bolt on hitch can be flipped to offset left or right to accommodate different distances between your tractors rear tires. That's what the directions said anyway.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Old 08-16-2014, 07:48 PM
Heres a few pics of the scouts for you Oak. The second one is my terra and 100 heading to Red Power Roundup 2014. The orange scout has original paint. And the plow scout has a 4" lift and posi front and rear axles.
Old 08-17-2014, 01:34 AM
o---o o---o is offline
Very nice Scouts! I had one the same color as the plow Scout back in high school.
Old 10-05-2014, 09:26 AM
Got to try out the plow at a plow day last month and it worked good. I learned that I needed some front end weight on the 71 as well as more rear wheel weight. I built the front weight bracket out of some wide frame seat springs. I had the rear wheels filled with rim gaurd which added 60 lbs to each wheel. I also put the cast wheel weights on the inside of the rims. Each wheel now weighs 125 lbs. I expanded my garden yesterday with the added weight and was turning over huge slabs of sod, but now with the added traction the clutch is going to need attention because it was slipping some.
