Old 09-08-2018, 08:30 PM
cooperino's Avatar
Hey bllwnkl
Did you find your issue?
Old 09-08-2018, 10:53 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Originally Posted by cooperino View Post
Hey bllwnkl
Not looking right now. Too much work to get to it in the detached garage while it's raining. (I got the lawn mowed for now so, no hurry)
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 09-17-2018, 06:01 PM
bllwnkl's Avatar
Default So that wasn't it
Took a moment to look at the 1250 thinking that if it's a safety switch, I have another one.
But for kicks, I sat on the tractor and tried to start it before checking anything. It works. So, it must have something to do with being hot. Isn't that indicative of a coil problem? Anything else? please.
Randy
Old 09-17-2018, 06:03 PM
cooperino's Avatar
Condenser?? I know condensers will make run erratic but will it keep you from running? Maybe
But yes. could be coil
Old 09-17-2018, 06:22 PM
Inactive Member
If the coil goes bad when it is hot, the engine will still roll over when the starter is engaged. It just won't start due to lack of spark.
Old 09-17-2018, 07:11 PM
cooperino's Avatar
Had to go back and look. Roland is correct. You had a crank issue last time right?
Old 09-17-2018, 07:17 PM
Shotgun Clay Shotgun Clay is offline
I had a similar issue with my 149, the switch spring had broken almost all of the way and would sometimes have enough to push the button. It would not work because it was broken, but somehow did until I fixed it.
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 09-17-2018, 11:25 PM
bllwnkl's Avatar
I had nothing at all. Turn the key and no sound or anything.
Randy
Old 09-17-2018, 11:36 PM
If it came back on it's own, I'd say you have a bad connection. Check the starting circuit over.
Old 09-18-2018, 04:56 PM
sorner's Avatar
sorner sorner is offline
Originally Posted by RChristensen View Post
Sound like the old “wiggle the PTO switch while turning the start switch”. Seen a lot of those, almost like a safety switch to keep people from starting a cub if they didn’t know the trick.
My 1912 has done this since I got it. I traced and retraced wires after it started this crap, and I just happened to mess with the switch on the right side (it has two PTO switches) while turning the key, and it cranked. This only happens after running the engine with the PTO on. If I jiggle it while turning the key and it starts, and I run it without turning the PTO on, it will start up again later without the jiggle method.
Not trying to steal the thread here, just agreeing that could be the issue with an explanation of my experience with a similar issue.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
