Old 04-05-2013, 10:35 PM
CadetTY's Avatar
CadetTY CadetTY is offline
Bump.
All these cubs being fixed up there should be many people posting! Lol
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 04-05-2013, 11:16 PM
IHinIN IHinIN is offline
I have a Harbor Freight cabinet and a 60 gal compressor. I use garnet sand in it.
Old 04-06-2013, 06:53 AM
PaulS's Avatar
PaulS PaulS is offline
I bought a sand blaster at Sears for about 70 dollars. My compressor set up is a 5 horse 220 compressor with a 15 gal tank hooked to a 80 gal tank. The blaster works pretty good but after trying electrolysis to remove paint and rust the sand blaster just sits there looking dejected. Electrolysis takes longer but without the dust and mess of sandblasting.
Old 04-06-2013, 12:17 PM
colt54 colt54 is offline
I use a 3500 psi power washer with a sandblaster kit. If the part is real rusty I will use sandblasting media, If its just surface rust the play sand works well for me. One thing to remember with play sand is to open the bag and let it dry, Because moisture will clog the nozzle. You do get wet but on a hot day its fun and cool, and no dust to breath in. Yes it will start to rust because of using water but time and a wire wheel shines it right up. I got some rims to do in a couple of weeks, If I remember I will take some photos of them.
Old 04-07-2013, 07:44 AM
You can get dry sand in the mason supply dept. Quik Crete bags it. I used a couple bags of it. I like sand blasting sand better because it doesn't have as much fine stuff and it cuts faster. TSC should have it. I got some at the local NAPA.
Old 05-28-2013, 09:18 PM
I'm shocked that no one where has the "big" harbor freight cabinet (40lb cab)! My Dad has one and it works shockingly well.. It's JUST big enough to get an inline 6 (258) oil pan in. It would be almost perfect for a cub hood if you don't mind opening the door to flip it around. For $200 it's a criminal steal. His compressor is some ancient thing from 1953 (honestly) that has been piston slapping for at least the past 20 years.
I have no idea what media he has, but I'm betting its not much better than play sand.
When I have a job that allows me access to a cabinet, they are usually using a coarse aluminum oxide media.
No matter what blaster or media you're using, hitting your part with a wire wheel on an angle grinder before blasting will save you at least 1/2 the time.
Old 06-15-2013, 06:45 PM
Played with the pressure washer sandblaster today on the dump bed for my Deere Dumper. Got most of the nasty stuff off before I ran out of sand. Before and after pics. I like this tool!
Old 06-15-2013, 07:26 PM
You've been busy, Sam!
Old 06-15-2013, 08:28 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Sam, your garage always looks absolutely spotless.
Always impressed !
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 06-17-2013, 10:26 PM
Wow..... That pressure washer sandblasting really looks like it's the ticket!
... are those 2 1" cylinders on that dumper? I think the bed needs bigger (3140lbs/ea @ 1000psi)!!!
Always impressed !
Yeah.. That SOB even has the little 5 drawer side box for his tool box!!! I say we boycott Sam for having a better shop!!!
He's cheating!!!
