Old 06-12-2020, 09:49 AM
If you had a hydro you would have infinite speed range, from nothing to max swash, no need for hi/low range.
A super garden tractor has 1 tooth less on pinion gear on the hydro to compensate for the larger diameter tires they put on them.
If you had a hydro you would have the ability of adding power steering and power beyond to activate a lift cylinder or additional circuits for power angle.
You would however be limited by speed of these as your GPM's of the charge pump are too small for something like a log splitter/loader but you could add an additional pump of higher GPM's.
just something to think about
Old 06-12-2020, 11:24 AM
Watch this video (start at 15 minutes, 27 seconds [15:27]) to see a Cub Cadet with loader perform using the charge pump only to power the loader,,,
https://youtu.be/eTjuozhzwBc?t=927
To see the machine operating, skip the explanation, and jump directly to operating,,
https://youtu.be/eTjuozhzwBc?t=1141 (start at 19 minutes)
Old 06-12-2020, 11:30 AM
Oh, yea, if I tinkered with it for a while,, I could get the charge pump to split some firewood,, too,,
maybe not 36" blocks of gum tree wood,, not a pickup load in 15 minutes,,
but, it would split most of the firewood a normal human wants to use,,,
I say that because I built one back in the 1980's ,, and it worked for me,,
I did not take any pictures,,,
Old 06-13-2020, 10:42 AM
On the 2nd green machine video....
It's a wonder that helper still has his head in one piece!!
Gawd, what a lousy operator!
Sent chills down my spine watching that!!
