Old 12-25-2018, 02:43 PM
rockne10's Avatar
rockne10 rockne10 is offline
It does take a few seconds to power down. I tried feathering the throttle; helps minimally, but didn't try the choke.
Well, now that I've tried to replace the coil with one I can't get to fit, there's no chance of it even starting at all. I'm hoping I can resolve this before the grass starts growing in three months.
Would I be better off just finding a new engine I can just drop in? Would probably be cheaper than what I've already spent refurbishing the deck!
Old 12-28-2018, 07:55 PM
Jibber's Avatar
Jibber Jibber is offline
Where are you located in Central PA? I am in State College and could take a look at it. I have a 282 and recently found a NOS Shortblock for it and it runs perfect! Feel free to PM me.
Old 12-28-2018, 09:52 PM
heinriech heinriech is offline
Welcome to OCC! PA, south centralish here.
Old 12-29-2018, 07:25 PM
sawdustdad's Avatar
Put the old coil back on. Make sure you get the pos. and neg. terminals hooked up correctly. Bad coil is a low probability failure point.
Have you removed and cleaned the carb? That's the first thing to do. Drain all the fuel from the tank and remove the fuel valve from the tank. Clean the tank. Clean the carb and all the passages and jets. Re-assemble with a new fuel line and I bet she'll come to life. Check the engine manual for setting the jets on the carb. Wouldn't hurt to run some fine sandpaper between the points while you are at it.
