Old 12-06-2020, 04:26 PM
Mark4470 Mark4470 is offline
Sorry guys. Thanks for trying to help me. Let’s try this again.
https://www.youtube.com/watch?v=1VXF...ature=youtu.be
Old 12-06-2020, 10:08 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Well, your clutch is operating normally, but clearly something isn't in proper alignment. Definitely shouldn't be that much wobbling in there.
Other than that it looks like the clutch was engaging and disengaging properly
Replace the engine Isolation mounts and see what that does, could solve your problem
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 12-07-2020, 07:54 AM
I don't know if this is your problem or not. I bought a 1541 that had a similar clutch set up in it with similar symptoms.
Part #8 was broken. The spring steel center cracked.
https://www.partstree.com/models/120...ctor/clutch-5/
Old 12-07-2020, 08:29 AM
Thanks Mike! I assume I will have to pull the engine to tear the clutch down?
Old 12-07-2020, 08:45 AM
I think you can pull the engine forward enough when you change the mounts.
