The 2165 and 2185 are listed as garden tractors on tractordata and tractorgearbox websites. All the lower 2000 models are listed as lawn tractors. If they all have the same frame and transmission, then I guess it's just the more HP that gives them the extra umph for ground engaging work? Of course the only difference between a 2165 and a 2155 is one HP.
If if had bought a lower model 2000 because it was advertised as a garden tractor, then blew it up trying to do some ground engaging work, you better believe I'd be raising hell for false advertising and making them cover that under warranty. |
IF..........you really want to know, attach a 10" mold board plow to your 2155, go to a Plow Day Event, plow the afternoon (if it can) and see how long it lasts. If it holds up the entire afternoon, with no damage, then you have a Garden Tractor.
Which is generally determined by whether they're shaft driven or not
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
The brochures I posted are only a limited range of the HDS2000 series , these are the ones that were available in Australia
The chassis is a very common element in a lot of Cub models , my GT2550 has basically the same chassis as do other models and series As to whether they are Lawn or Garden tractors ??? My original Cub a HDS2155 was a good piece of gear and is still going strong in the hands of a mate As to price I paid AUD $5110.00 tax exempt , and that was an exceptional price JD , Toro and other comparable models were way over AUD $6000.00 Oz
My wife says I do not listen , at least I think thats what she said |
The 2185 are horizontal crankshaft Kohler command engines with shaft drive transmissions. The 2185 is quite comparable to the current xt3. My 2185 has 23x9.5 - 12 rear tires, same as the late 3000 series and xt3. I consider the 2185 as entry garden tractor. Maybe 2165. Below that, probably not.
Mark from Minnesota 3165 with CC Snow Blower, Front blade, Sims Cab 3185 with 3pt hitch, it runs now. But not well. 48in and 52in mower decks 2185 with mower from my dad when I have a project for it. Massey Ferguson Model 70 corn planter. CC yard cart |
I've been reading on other tractor sites and older posts on here, and it seems the 2000 series was kinda odd in the fact that it had a horizontal shaft drive and BDU-10 Hydro, yet was on a lawn tractor frame. It seems the 2000 and 3000 series were the last of the "good" Cub Cadet tractors before MTD started making all their brands the same with different logos on the stickers.
The only modern CC you can get with a horizontal shaft drive now is the XT3, which also has a BDU-10 Hydro. It seems the old big frame garden tractors are a thing of the past. Go figure... |
