Old 12-22-2016, 10:31 AM
Originally Posted by scarps68 View Post
So we had our first snow this past Saturday in CT. I came home from work early Saturday and attached the plow and put the chains on. Things were going great until....
Went to a hydraulic shop today and the guy said it would be worth just buying the $420 Cub Cadet cylinder. Paying $50 more for a new cylinder vs repairing the old. On the mission to find one from Surplus Center and modify what I have to.
Take it to these guys. http://www.mcgeewelding.com/ Ask for Vic. He used to weld all of my stuff. I'd bet you'll get it fixed for a 6 pack. Lance the owner likes Twisted Tea. Tell him that Sam his old racing buddy sent you.
Old 12-24-2016, 12:22 AM
scarps68's Avatar
scarps68 scarps68 is offline
I was hoping to have the cylinder rebuilt anyway because of a small leak, but for the price he was suggesting I would rather have new parts and still save over $250.
Sam thank you for the recommendation. I will definitely be checking these guys out.
Don
882D
50" Deck Mower
54" Snow Dozer Blade
Agri-Fab Lawn Sweep
Old 12-24-2016, 06:13 PM
mortten mortten is offline
In other words, the guy at the hydraulic shop, just did not want to mess with it!
They actually quoted you that price to FIX it???
X2. Guy didn't want to be bothered.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 12-25-2016, 12:47 AM
2009Dodge's Avatar
2009Dodge 2009Dodge is offline
I worked at a shop that reworked cylinder rods. I'm sure he gave you that price just for the heck of it. we wouldn't do any welding on the eye only dot welds on the rod face that got ground down and replated.. Just make sure the rod is all the way out. If you want to do the reseal kit yourself it's not really a big deal if you can get the spanner cap off. Just don't use heat otherwise you could mess up the relief. If you can't feel any scratches with your fingernail on the rod a reseal kit is all you should need and should be cheap even if you have someone else do it.
IH 782 with Kt 17 series 1
108
Old 12-27-2016, 09:07 PM
scarps68's Avatar
Originally Posted by ken6x6 View Post
Yep, that's definitely fixable by welding. Lots of rods have welded clevises from the factory. I've done it plenty of times and as mentioned just keep the rod covered and cool by the seals. I highly doubt the rod would ever got hot enough with that small amount of welding to transfer to the seals though.
If you were closer, I'd say drop by, I'll help you out.
Any certain rod you suggest to arc weld it? Or another process you suggest?
Don
882D
50" Deck Mower
Agri-Fab Lawn Sweep
Old 01-04-2017, 04:28 PM
scarps68's Avatar
A friend and I tried to extract the threaded screw in the cylinder and got no where. So I had a local shop weld it back together. Hopefully get it back together before next storm.
Don
882D
50" Deck Mower
Agri-Fab Lawn Sweep
Old 01-04-2017, 06:03 PM
Nice looking weld.
Old 01-04-2017, 08:13 PM
Nice looking weld.
I agree, if that breaks something else is going with it.
Pap's 100
Restored 108
1211 Dual Stick
1050
