Old 06-02-2022, 11:15 AM
Farmall450's Avatar
Originally Posted by Sergeant View Post
I Have found rustoleum Almond to be about the Closest Match
Originally Posted by 1711Cub View Post
The Rustoleum Almond is VERY close to the original 80's Cub cream. I've used it several times and have been pleased with it.
I'll try to find a few cans tonight.
Old 06-02-2022, 10:40 PM
Farmall450's Avatar
Wow, the almond is a very good match to the original rims (from 1984).
Should be able to mount the rear tires tomorrow (adjusted the brakes and lubed everything up under there tonight while the tires were off. Surprised the 3 point rockshaft doesn't seem to have grease zerks).
Old 06-03-2022, 08:07 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Wink
I painted the front hood side panels on my 1050. The Almond is virtually indistinguishable from the original paint on the hood. Actually it is closer than the OEM Cub Cadet paint I bought. The Cub Cadet yellow has been spot on though.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-03-2022, 10:34 AM
Farmall450's Avatar
It went on the wheel weights super thin. 3 coats and still not great coverage.
I used the Rustoleum transport yellow on the U hitch and sleeve hitch casting, and 1/2 coats over primer are solid.
Old 06-04-2022, 12:49 AM
Farmall450's Avatar
Got the new rear tires mounted and on the tractor. New meats sure make a world of difference. Also took off the #364 blower and then cruised around some before draining the hytran.
Drives good, steering tight, brakes work but LH pedal clips the cab mount before going all the way down to lock in the deeper positions. Seems to represent the meter hours.
Old 06-04-2022, 08:48 AM
1711Cub's Avatar
Smile
Nice tires. I see that the CCC decal on the tail is to the left of center. Must have been a Monday or Friday build.
Old 06-04-2022, 12:47 PM
Farmall450's Avatar
My only other thought is it clears the top link that way
Old 06-05-2022, 01:09 AM
Farmall450's Avatar
Picked up the mule drive and lift link I needed. As well as a spare #374 shell from Rob Houtz. My Stens blades also showed up. At this rate it might be mowing next week
325-908 Stens for reference.
Old 06-08-2022, 01:18 AM
Farmall450's Avatar
Tried to make some progress in between rain.
Primed the underside of the #374 deck and also the backside of the wheels. Right beforehand I knocked out the bearings and spacers and stripped the outsides to bare metal. Wasn't sure if I was going to reuse the bearings at the time, so I used a wire wheel, which was a mistake (vs sandblasting).
Turned out OK for my first foray into using a spray gun (way cheaper than all these cans), but I thinned the rusty metal primer too much (3:1).
Old 06-13-2022, 11:57 AM
Farmall450's Avatar
Finally got the fronts mounted. Next time I need to mount "smaller" 8ply I'm going to pay someone lol.
