Old 02-02-2016, 11:08 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Then what do they use.......????
Iirc the manual says 625, but the brake line will hold at least 900+ psi. Seen it
1- 1200 in pieces
1- 1864 in pieces
Old 02-02-2016, 11:42 AM
Inactive Member
I just looked in the service manual. It says: "The lift pressure is regulated by the lift relief valve at 500 to 625 PSI." So my statement wasn't incorrect.
As far as 3/8" steel brake line tubing, from the data I have seen, it states it has a working pressure of 1800 PSI and a burst pressure of 7400 PSI.
So, what information that I previously stated was wrong...???
