I know all too well about the back problems my friend. Watch what your doing and be careful.
As for the hard starting take a look at this link for setting your timing. It may help a lot. Also you may need to look at going thru and rebuilding your carb if you haven't done it yet. Does your carb have an adjustment on both the top and the side or just one on the side? http://www.onlycubcadets.net/forum/s...ead.php?t=4405
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Thanks DWayne,
I did do the static timing procedure but I re-read the link you provided and noticed the part about backfire through the carb. This one does that which is why I thought it could be the compression release but I might better check my work as this was a first time procedure for me. I did not clean up the valves when I had the top off. I did not get the carb off and cleaned either. I believe it does have the adjustment on top of the carb but will have to wait for daylight to check for sure. I couldn't see well enough tonight without removing the base of the cover. While I'm laid up here I hope to get some of these bench top things done if I can. Curtis |
