One lonely old 1541, 3pt, Brinly plow and cultivator. |
Gene I see one of your older threads has been resurrected. Any pics? You doing ok?
On the aftermarket carb I referenced above, the shaft is brass. So the choke lever had to be braised back on after rotating it 180 degrees. One of the shop guys I work for actually tig welded it with silicon-bronze filler. |
correct choke
I bought one on e-bay a couple of weeks ago that was advertised as having the correct chok lever, it was a #30 for my 169, it was, as advertised,and my k341 has never ran so good
older post but hey someone else may want to read this. I brought one of those carbs a week ago, same carb, same place. It runs great, idles good and revs nice, I did not remove choke to fix it, all I did was cut a triangle piece of metal and drilled a small hole in it, I then migged it onto the side of the existing flange of the choke. It looks original and operates good, took only a little bit of time to do and it was an easy fix, the flange is metal not brass, the shaft I don't know, could be brass or metal, did not check.
Cub Cadet 1968 105 with Spring Assist & 3 point Hitch 42'' Mowing Deck QA36 Snow Thrower 42'' Tiller Snapper 1983 LT1100 1967 Mustang Coupe RestoMod |
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
