If grass is thick,wet, lush and tall, it ain't ah gonna mulch.
Mulching is best accomplished when frequently cut and grass is left tall so clippings have a place to hide while they decompose. looking at yer pictures I'd run a pair of calves on that place and have nice jucy steak's and burgers in 18 mo. OR: Take 3 cuttings of hay put into square bales and feed it or sell to someone that has horses, especially in a drought year $$$$ BTDT. |
When Mulching, I only up to about a 3rd of the total height. Or about 1.5 inches. Any more than that and I get the same result you have.
You should never mow more than a third of the grass's length, and you shouldn't be mowing wet. My uncle has a ZT1 50 Kawi and none of the issues you have...although he's known to occasionally bag if he lets it get out of hand.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I can certainly open the shoot back up. It’s only been mowed twice with the mulching kit on it and I However, I don’t think I can mow more often than every 5-6 days. To be clear, those photos are of a 6 day cut without the mulching kit.
When Farmall450 mentioned opening up the chute I believe he meant more than just removing the mulch plate. Because of liability issues nobody on here will tell you to remove any safety devices. That said, I personally would start with raising the deflector and if that wasn't enough I would start looking at modifying the deck chute to allow the clippings to exit the deck easier. Anything you do is your decision. Good luck.
