Ironman, how long is your wagon? What kind of steering does it have?
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead. |
It is 36" wide by 60" long. The front knuckles and spindles were from some old riding mower, and the tongue steers them like your standard hay wagon. The frame was fabbed from 1 1/4" x 1/8" steel angle. The bed is plywood covered with aluminum sheet from the side of an old camping trailer. Has stake bed sides about 18" high, made of 3/4" treated wood, when all four sides are removed it is open flat bed. The wheels and tires are the 10" jobs from Harbor freight. Rear axle is just apiece of 5/8" x 36" steel rod. Built about 18 years ago, still in great shape. I don't haul anything massively heavy in it but I don't think something like a couple automatic transmissions would be any problem. Hope that helps. |
Does it make a pretty good garden cart, too? I see that plastic cart with a monkey on it has an end that switches from hitch pin to handle.
Can you push it around the flat with a light load on it pretty easy? A few transmissions worth of scrap weight sounds perfect for my needs, or at least just enough to haul the rest of the donor carcasses off to become a new Toyota. I think I'll have 7/8 spindles, they should hold up to more than the 5/8, in theory. The more I think about it, if I use one front axle per wagon, I can build 2 sets of running gear. It sure would be nice to have a water wagon that I can plumb into my downspout or take down to the creek when it doesn't rain.
