I already have one of these. 2 U joints, and telescoping.
Scot |
drive shaft looks a lot like a snow thrower unit?
Good work on the modeling. Your system is high end. Will be watching. Like Matt said, I took a look at several builds too. (my 4x4 project has been set aside) I really like the idea that the seat would stay aligned/attached with the front of the unit and let the back portion move/rotate under the seat area. I know this may not be easy to do??? Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
It is a drive shaft for a Cub Cadet snow blower. The openings in the ends of the U joints is 3/4" & the hydro pump input is 5/8. I found spacer sleeves on eBay to adapt from the two sizes.
I need to drill a hole through it for the roll pin/bolt yet. I'm going to connect the seat to the front half & so it is not pivoting between the seat & steering wheel. As I mentioned in another post, the articulating Cab of Glen Peterson is my inspiration. I have traded emails with him about his design. His has a Yanmar diesel engine. I'm still looking for a motor. Glen's Cub: Scot |
Your design is similar to that of a versatile except it uses two rods across the top.
Scot,
That 4882 is a great tractor build. Regards, Chris
Isn't that 4882 cool. It belongs to Glen Peterson, he is in Wisconsin somewhere.
Scot |
Little update.
Scot |
That is neat!
You will need a U-Joint for the drive shaft to the rear axle in line with the pivot point.
Ive been playing with my auto cad program a little for a 3 seat 125 w/dump cart. Ill get to that project next winter I think.
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
