You just need to fill it to the top of the fill plug, run it for a little bit, then fill it back up again. The volume is good for purchasing the fluid, but this is how you fill it.
127 Hydro Problems
Harry-
Make sure you use the correct oil for the Hydro!! I believe the manual recommends Universal tractor hydraulic fluid, not 80W90 gear oil. BTW where in Bavaria are you? I lived in Karlsruhe for 4 years from 1987 to 1991. My youngest son lives near Kaiserslautern now. Utah Smitty |
@Utah Smitty i live near Augsburg
I'll take the HY Train Ultra Oil should be correct according to the Manual cu Harry
The other German cub cadet driver cub cadet 127 Danco loader RD2000 ---sold cub cadet 104 ---sold Gutbrod Sprint 1000 |
Harry, you are correct. Use only Hy Tran in your Cub Cadet.
Hi guys
is the part A to part B is welded to the image? with my Cub moves part A and the weld looks as if it were broken out have now brought new oil-filled but hardly an improvement cu Harryold
because no one knows how the part should look like? The cub will be happy together again to build ..
cu Harryold
Harry those are two seprate parts. Here's the link to the parts look up.
http://www.partstree.com/parts/?lc=c...&dn=0019900012 |
I mean the part nr 50 .. is movable on the shaft or fixed?
http://www.partstree.com/parts/?lc=c...&dn=0019900011
I'll try to weld times ..
thank you cu Harryold
