IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
For the record, the Operator's Manual for the 104 specifies that the transmission takes 7 pints of Hy-Tran or SAE 30 engine oil.
I use 2 liter soda bottles with the pointed gear lube bottle caps on them for nearly everything oil related. They work great, just don't squeeze them too hard.
I got one of these at Wally World.
http://www.walmart.com/ip/FloTool-Tr...Spout/16889149 The FloTool Transmission Fluid Spout comes with an on/off spout for adjustable flow. A reduced tip and 12" length makes it perfect for transmission filler tubes. An adapter allows the spout to fit on quart and gallon containers. FloTool Transmission Fluid Spout: On/off spout for adjustable flow Reduced tip 12" length Perfect for transmission filler tubes Adapter allows the spout to fit on quart and gallon containers Polypropylene Works really great putting fluid into Cubs rear end.
Original, 109, a pair of 122s, 124 with power lift, 124 with creeper, 126, 147, 1050, 1200, two 1250s, 1450 Dual Stick , another 1450, two 1650s, Gannon Earthcavator, Haban sickle bar and a bunch of other things you either pull, push or hang underneath. |
I know this is an old post from 2013, but I thought it was better to resurrect an old post than start a new one with the same topic. I have a 1969 124 (so it is a gear drive), so naturally, this question pertains to Gear Drives only. I know the manual says to use Hy-Tran OR 30W oil. My question is, has anyone used 30w oil, and did you notice anything different in the way the tractor performed? Also, if I use 30w, I should use non-detergent just like the motor, correct?
Thanks. |
So I drained about 4 inches of water followed by 4 inches of snot out of the back of my 124. I used the Tractor Supply “traveler” brand hydrolic transmission fluid. Again, this is just a gear drive. It runs very happy now. No leaks, and it actually shifts into gear now without having to rock back and forth on the seat to get it to go into gear!!
